My brothers 90s crown vic uses alot of oil. Not leaking and not really burning it. Tried PVC and hoses. About a quart in two weeks. Any ideas?
Mystery oil loss
Nothing that could account for the volume lost.
Pop the breather cap off the valve cover and see if a lot of smoky oil comes out from blowby like a mofo2000 Grand Marquis LS
Mercury Owners Group member
He hasn't said anything about the plugs fouling, will have to ask him2000 Grand Marquis LS
if it'snot leaking out onto the ground,replace the pcv screen.........might be clogged.........or the engine was overheated at one time and the oil control rings on the pistons are toast.........my towncar burned a qt every 400 miles like clockwork
scott
If it's a 4.6 car, then the problem is valve seals. '91-'95 4.6 heads had a poor design that will cause oil usage over time. The amount of usage varies, but it will be seen in the form of blue smoke out of the tailpipe when the car takes off from a stop, or idles for long periods.
RayCar: 2004 Mercury Marauder
Engine/Tranny: 49k miles and bone stock....for now
Originally posted by Johnnyirocrear seal? running onto torque converter, but somewhat held up by the converter hole plug, so it just slowly drips out? BTW a 90-91 CV is for the 5.0/5.8 boys. This thread may be better served there depending what year he has.2000 Grand Marquis LS
Originally posted by lincolnmaniareplace the pcv screen
Originally posted by lincolnmaniaoil control rings on the pistons are toast.........
scott2000 Grand Marquis LS
Originally posted by 93 MarquisIf it's a 4.6 car, then the problem is valve seals. '91-'95 4.6 heads had a poor design that will cause oil usage over time. The amount of usage varies, but it will be seen in the form of blue smoke out of the tailpipe when the car takes off from a stop, or idles for long periods.
Ray2000 Grand Marquis LS
I second the valve seals. 92-95 model years have this problem. Those early (or pre-NPI) 4.6's are notorious for it. Not unlike Chevy's 305 from what I hear.
The valve seals are not a problem on 96+ 4.6's though, Ford used better valve seal material after that.2000 Mercury Grand Marquis LS HPP.
http://www.cardomain.com/ride/2336322
Friends don't let friends drive donk.
On the difficulty scale I'd rate doing your own valve seals at a 8+. Getting the passenger side valve cover off alone is a battle.
Having it done at a shop will cost $600 & up, provided they want to touch it. As BigTomZ said, Ford addressed the problem in the '96-up heads. At the labor cost of the job you could pick up a newer low mileage 4.6 and replace it.Car: 2004 Mercury Marauder
