Cold Air Intake
  • SVT98t
    replied
    here ya go...
    i made mine from one of those cheap $20 kits on ebay. its for a 99 mustang gt. i just had to make the holes on the pipe that connects to the maf bigger. and some precise cutting. i had a problem of the piping running into the oil cap, so i got a throttle body spacer and now it clears it perfect. and i have the heat shield on there from my marauder.
    Leave a comment:
  • 96'vicp71
    replied
    I have a 96 p71.....just about 100k miles...Would a Cold air intake be a good idea? If so where could I get one for a 96?
    Leave a comment:
  • embharris
    replied
    Any directions on how to put this on vehicle?
    Leave a comment:
  • merc6
    replied
    Originally posted by p71towny
    Ha, you did the same autozone honda tube as me, except I bought it when it was $25, they jacked up the price on those things for some reason.
    Popular item after the F&TF movies+gas price rise=price. Gas went down but prices of other things still stay up there. Techron fuel system cleaner went from $5.99 to damn near $13
    Leave a comment:
  • p71towny
    replied
    Leave a comment:
  • merc6
    replied
    I need one of those hairdryer thingies
    Leave a comment:
  • HwyCruiser
    replied
    I used to have a homemade airbox for the K&N filter that came with the ProCharger kit. It drew air from the stock location behind the headlight using the stock airbox rubber boot.
    Pic
    IAT at idle was a solid 25 degrees above outside air temp and 15 degrees above on the highway. The IAT sensor is screwed into the cast aluminum right angle plenum that attaches to the throttle body above the driver's side cam cover, so radiant heat had a lot to do with the temp rise.
    I started to design a better looking airbox but then got busy with other stuff, so the air filter has been exposed to the engine bay for awhile. IAT at idle can get 45 degrees above outside air temp and usually 25 degrees above on the highway. Drawing air from outside the engine bay does work, if you can get it.
    I need to get back to that project.
    Leave a comment:
  • lsb532004
    replied
    I found a PI Zip tube from Blue Oval Chips.com for $42.00. I installed it on a 2004 Grand Marquis with a Cone K&N and it works great!
    Len B
    Leave a comment:
  • mercenvy
    replied
    Originally posted by importssuck
    Spectre Intake Tube
    Part # 8219
    Price $49.99
    Hellova better deal than that pi zip tube
    Thank you very much for the info...
    -mercenvy
    Leave a comment:
  • Grandmarchris
    replied
    Spectre Intake Tube
    Part # 8219
    Price $49.99
    Leave a comment:
  • mercenvy
    replied
    Ill get those for you when I go to work tomarrow man
    Cool, I helped you with the grille removal and you're hooking me up with zip tube info. Can't you just feel the love...lol
    No hurry, though. I just got my service CDs and have been been balls deep in wiring diagrams for my 4V swap. So take your time.
    Leave a comment:
  • Grandmarchris
    replied
    Leave a comment:
  • mercenvy
    replied
    I got it at Autozone.. But make sure you get the metal one because you have to put a small dent in it to make it fit over the Fuel rail..I did mine with a rubber mallet...The ends of the pipe were kinda bent up but I fixed that a little with a block of wood and a C clamp..It looks good untill you take the pipe off...Theres some wrinkles in the ends but no leakage issues yet..
    Im more worried about that hole getting the filter soaked when its raining...But if the mustang guys can do it I can too.
    Any part #s for that zip tube? Price?
    Thanks.
    Leave a comment:
  • Grandmarchris
    replied
    Leave a comment:
  • mercenvy
    replied
    Where did you get the zip tube, if you don't mind me asking? It's hard to find something that fits on the forward-facing TBs of the early aeros.
    Nice setup.
    Leave a comment:
