Hey Guys,
I have just installed dual exhaust with 18" SST tips.
The tips are 304 SST, 18" long, ROLLED and tapered ends. THey DO NOT have moisture drain holes at the end. Should I drill a hole for drainage in the bottom? It appears that the moisture is dripping over the rolled edge and is leaving a mark.
Should I drill a drain hole? Please chime in.
Thanks
Len B
Thanks
Len B
