I have a 1992 Grand Marquis LS and everytime I get in the car and drive about 20-30 min my air supension light comes on. Has anyone else had this problem?
Air Supension Problem
As you drive the system automatically adjusts ride height. If the compressor runs excessively long (more than 45 seconds - 1 minute) the system shuts off the compressor to keep from burning it out. It then turns on the "Check Air Suspension" light to let you know there is a problem.
My guess would be you have a slow leak in the air ride system. Most likely place would be one, or both, of your rear air springs. You can check the bags with soapy water. Support the car on ramps or jack stands and look for cracks in the rubber near the bottom where it folds under. Cover the cracks with the soapy water and look for bubbles.
Does the car "sink" over night or if you leave it parked for long periods?
RayCar: 2004 Mercury Marauder
Engine/Tranny: 49k miles and bone stock....for now
Thanks
Thanks, I ll check it out tommarow if it aint raining tomarrow. Since I gotta change out a blower motor on my dads car anyway.
P.S. What kind of wheels are on your Grand Marquis? Because they look awesome.R.I.P Linsey Nelson
Originally posted by MeanVic84Chocolate Rain. Some stay dry and others feel the pain.
Hi All
Vent solenoid siezed closed? when you get out and close the door does the car vent (sink a littel at the rear)?
Regards
DereckPresident and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
Hi ImportsSuck
If your car doesn't vent when you switch off and get out, it sure sounds like you may have a siezed vent solenoid, I am not sure how much like a Town Car the Grand Marquis is but check out this link http://www.lincolnsonline.com/article61.html for some diagnostic help.
Regards
Dereck
PS My Town Car is an Import, does it also suck?President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
Reply
Thanks Dereck that helps alot! Even though its for a TC. I had no idea how the air suspension works utill I saw that.
ps The SN ImportsSuck is from those little 2 fast 2 furious wannabe rice-rocket Honduhs that buzz thru my town . Ive gotta get some pics of them. Trust me u will laguh when u see them.R.I.P Linsey Nelson
