Hello all,
I have a 2K GM which has a problem the no body has been able to fix so far. I have payed out over $1500 in repairs and the car still does the same thing. I have taken it to three dealers and two other shops. They Have all come up with something they said was the problem has turned out to not be it, but they still charge me for thier wrong guess work.
OK here are the symptoms, the car will start and run fine then cough at a point like ignition loss, the low coolant lite will flash, the trak control light comes on and stays on, it will then run ok, but intermitenty miss ,"cough", on acceleration. At times it will stall too upon acceleration. If switch the ignition off and re-start the trak lite goes off it will run fine again smooth until it happens again. It does this intermittenty but somtimes it will run for days without having its problem. The Check eng lite does not come on unless its a time when it stalls, then all dash lights do.
One dealer said it was the PCM / ECM so they changed it but it did not fix it. Next told me it was the wiring harness but since they where wrong the first time with no refund of corse, at this point am not whiling to let them take another $1000+ guess.
Anybody have an ideal what this might be?
Thx
Thx
