No, as Blaze already stated. Mustang pullies are are closer to the block than the panthers.
Underdrive Pulleys
Originally posted by Blaze86VicGet an electric smog pump. And the smog pump actually will not effect sensor tests. The smog pump only causes the CATs to start working sooner. And since all emissions test are required to be run on a warm car, it will still pass without it. Unless they do a visual inspection. But if you get an electric one you don't have any worries.
LOL, have you even looked at your car man? The alt and PS use the further out pulley....Sure you can space it out-need about a 2-3inch spacer. Get someone to machine you a nice billet chunk of aluminum-which would cost about the same as the ASP underdrive...
Capridrifter...All of my cars have passed w/o the smog pump. As stated, the smog pumps is really just for getting the cat going quicker.Builder/Owner of Badass Panther Wagons
Originally posted by capridrifterOkay Cool thats going to go the first chance I get!!!Builder/Owner of Badass Panther Wagons
Mine passed smog without it, but I have fairly new cats. If your cats arent properly functional, you might need that extra air to get it working.86 Lincoln Town Car (Galactica).
Originally posted by mrltdLOL, have you even looked at your car man? The alt and PS use the further out pulley....Sure you can space it out-need about a 2-3inch spacer.
Still claim it will be 2-3" spacer needed to bolt the Mustang pulley (first pic) instead of the Panther one (second pic)? Then there is always this:
It's a 52% crank pulley for a 5.8 truck engine - will these bolt to our engines?
yes, they will bolt to it. The balancers are the same.. Mustang one will still need some spacing. That truck one is way to small.. A stock stang one would probably be enough underdrive. A mustang underdrive will probably be too much underdrive for a vic. Might want to check out a stock truck pulley though.Builder/Owner of Badass Panther Wagons
A.K.A Kaptain Kanuck, Your Connection To The Great Land Of Eternal Winter and Incredibly Rusty Cars
- Oct 2006
- 2083
- Ontario
- Send PM
Lucky for me, any car I drive will pass an emissions test. I run them for a living. Also nice having access to a dyno.sigpicVic Videos Here http://www.grandmarq.net/vb/showthre...676#post243676
- Oct 2006
- 2083
- Ontario
- Send PM
Actually, you wouldnt believe the shitboxes that pass, volkswagon jetta with 650,000km on it blowin blue smoke sounding like theres a jar of marbles floatin around the motor, still passed(not by much mind you) and then the opposite, I had a 2002 nissan sentra fail last week. But employee vehicles always pass But anyways, this is off the topic of underdrive pulleys, so no more posts on here from me, got the info I wanted. Thanks everyonesigpicVic Videos Here http://www.grandmarq.net/vb/showthre...676#post243676
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Ohh, didn't realize you could order it un-anodized...I may have to do that...
