I want more bottom end power. As much as i can get. Stock heads, gt 40 upper and lower and maybe bigger tb will be on by the time the cam goes in. Stock stang heads and 2.5 offroad h pipe and flowmasters are on too. Engine is stock other wise. Or would I be better off just getting 1.7 RR's?
Suggest a cam
Suggest a cam
1989 Grand Marquis LS
flat black, 650 double pumper, random cam, hei, stealth intake, Police front springs, Wagon rear, Police rear bar, wagon front ,exploder wheels, 205/60-15 fronts 275/60-15 rears, 1 5/8" headers, 2.5" offroad x pipe, Eclipse front bucket seats, Custom floor shifter, 4.10 gears, aluminum driveshaft and daily driven. 16.77@83mphTags: None
I dont give a shit about smoothness. More lope sounds better. I want power damnit!1989 Grand Marquis LS
Ive got 2 maybe 3 sets here, just need valve springs.Originally posted by mrltdlope doesn't mean power....some e7's would help...http://secondhandracing.com/Home.aspx
truck cam or Explorer cam will get you substantially more low end, but I'm with those guys, big intake on stock heads will lose torque because you'll have poor air velocity. Would be better with just an HO upper and the truck cam or something. It should also let you get away with the stock ECM, or at worst case you'll need to switch to the truck ECM and re-pin the injector harness for batch fire which isn't that huge of a deal.86 Lincoln Town Car (Galactica).
e7's are mustang headsOriginally posted by 88VicI probably asked this before, but I forget these things. What exactly are E7s?
