Ok, so I've wrote down all the things I'll be doing to my motor and I've determined that my HP should be between 370 and 380hp.
is there anything else I can do that will put me at or above the 400 mark without denting the wallet anymore than needed.
I'm looking for mods that are below 300 bucks but will add about 20-30hp more.
Here's my list:
-MAF conversion
-65mm Throttle Body
-Ported HO upper intake
-Holley system max 1 lower intake
-24lb injectors
-Ported E7 heads
-1.7 roller rockers
-E303 cam
-Boring block .030 over to 306 and installing:
Kieth Black Hypereutectic pistons
new bearings and Piston rings
-Tune up with MSD stuff
-Holley fuel pump
-Adjustable fuel pressure regulator(Holley)
anything else I can add without slaping on a carb, nitrous or super/turbocharger?
Here's my list:
-MAF conversion
-65mm Throttle Body
-24lb injectors
-Ported E7 heads
-1.7 roller rockers
-E303 cam
-Holley fuel pump
