Any one have a wiring diagram for a 1984 LTD??? (The baby LTD) I need one to check out the stereo wiring for the rear deck speakers... some idiot cut the speaker wires.. and I am re-installing the plugs with some aftermarket style plugs... just want to make sure i get every thing right... Hopefully someone has a set on PDF they can e-mail me.. Tom....
1984 LTD.. Wiring diagram???
http://www.tomspolicecars.com/Tags: None
sorry, i dont have anything on the computer, just in the books.
Hmmm, luckily for me when I installed the speakers in the rear of my LTD, the plugs were still there so I just wrote down what was the positive and negative colors on each side, then used regular spade terminals. Sadly... I have long lost taht piece of paper. '84 shouldn't use a common ground.
I have the 1984 LTD Wiring Diagram. Do you have the premium stereo with the amp?
If so, there is a pink & light blue dot wire for left rear speaker, and
pink & light blue stripe wire for right rear
dark green w/orange dot wire for right rear and
pink & light green stripe wire for the left rear speaker
If not, the black w/white hash wire is a common ground for all 4 speakers the wire goes to the right rear then splits off to the left rear.
gray w/light blue hash is left rear
orange w/red dot is right rear
Stereo
I have the four speaker stereo, guess that would be a premium sound system? (For 1984!!!) Thanks for the help... If you ever decide to copy that, (Scan to a computer) let me know... Would like to get a copy....
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
I need your E-Mail address so that I can send you the scan of the radio wiring.
