I didnt want to highjack the other fuel pump thread but my question is,will the stock pump send enough pressure for the HO 19lb injectors? Or is that all controlled by the regulator on the rail. If so,should I change my regulator since I used my lopo rail and regulator?
I didnt want to highjack....
The stock pump should be OK, and the regulator controls the pressure. All ford injectors use the same pressure, and the HO and lopo regulator are the same.
And regardless, it's the volume, not the pressure you need to worry about.Builder/Owner of Badass Panther Wagons
i have two ho converted boxes, both have stock fuel pumps......the fuel pump can handle a ho 302 mang
Near stock HO should be fine if the fuel pump isn't already dying, but if you build a decently more powerful engine that uses more fuel then an HO, you may need to upgrade. Stock HO isn't a problem. Mine is running on the original 153k mile pump and its doing OK.86 Lincoln Town Car (Galactica).
