Ok, hears what i have got so far, 1985 5.0 truck block with pistons and crank, and it had its stock heads, I am going to build this engine and hopefuly put it in next year,
Things I have done so far,,,
*replace oil pump so i can put my new oil pan on(insted of the truck pan)
*pulled old head's off (pistons only have small noches for valve clearence, Higer compression??)
Stuff i have for the engine
* 351 W heads casting # D0OE-C (Pedistal rocker mounts)
* H.O Headers
* Double Rollar timming chain
* Brand new oil pan (car style)
* Distributor
Things I need for the engine
* H.O cam and rollar lifter's
* Rollar rockers
* 4 BBL intake and carb
Things i am going to do
* Port the heads,
* Do a valve job
Will add more and have pics in a bit
* H.O Headers
* Distributor
* Rollar rockers
* Port the heads,
* Do a valve job
