Only Towncars in Florida can not have AC.
1989 Town Car HO Conversion running rich
i would bet money that the stock egr spacer isnt sealing to the explorer intake
Its sealing (I've checked twice) but the sealing area is like 2mm wide..............1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
PROBLEM SOLVED!
Thanks to N A on here, I got a Lightning EGR spacer installed, and I installed an HO throttle body.
Put it back together, hooked it all back up using the Mustang IAC with the plug inverted and vavooooom!
Car idles like STOCK
I also gained at least 1,000RPM before it shifts now too, which is kinda freaky. I don't know if its pinging or not, kinda sounds like it, so I may have to switch back to high test, or, it could be the insane carbon build-up from it running so rich for so long.
In any case, it runs like a TOP!!!!!!!
Thanks for all your help guys and a special thanks to Gadget for hooking me up with N A.
-Chris1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
I think this is where I say "i told you so" Good to hear its running properly.86 Lincoln Town Car (Galactica).
Originally posted by gadget73I think this is where I say "i told you so" Good to hear its running properly.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Sweet dude! I have a 1989 HO converted towncar as well, except I wish I had explorer intakes and 1.7 RR heh. I had the same problem with surging as you did, then Scott and Thain dropped by and found that my EGR wasn't sealing to my intake!! As soon as I fixed that it idled "like stock" as you said. Sure is fun beating on ricers with a big old Town Car heheheheh.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by 89LincolnTWNcarSweet dude! I have a 1989 HO converted towncar as well, except I wish I had explorer intakes and 1.7 RR heh. I had the same problem with surging as you did, then Scott and Thain dropped by and found that my EGR wasn't sealing to my intake!! As soon as I fixed that it idled "like stock" as you said. Sure is fun beating on ricers with a big old Town Car heheheheh.
I didn't "race" him per se, he gunned it away from the lights, so I just kinda hung with him, he floored it, I hit 'er, pulled away from him, got about two cars on him, and then let off, and the look on his face as I went by him............ Never exceeded the posted limit1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Oh, and to add, I put the ACT in #5 runner as well.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
sweeeeet! oh man the other day, I was at a light and a yellow mustang pulls up with some 16 year old and his buddy inside, cranking their crappy music. I had a feeling they would gun it off the light so when it turned green, I floored it and he floored it....the look on their face when I started pulling away was priceless...priceless I tell you hahahaha. It was a 2004 or so V6 auto, I doubt I could hang with a GT, at least until I supercharge this beast!1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
the lightning EGR spacer is Required when you run an Explorer or GT-40 intake, the stock (bored out) EGR spacer simply wont seal and it ends up leaking vaccum into the back side of the spacer.
BTW... I have run my ACT sensor in both the stock location and in the fresh air intake. Really dont notice a difference either way.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by 88grandmarqthe lightning EGR spacer is Required when you run an Explorer or GT-40 intake, the stock (bored out) EGR spacer simply wont seal and it ends up leaking vaccum into the back side of the spacer.
BTW... I have run my ACT sensor in both the stock location and in the fresh air intake. Really dont notice a difference either way.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Just be careful racing people or you'll end up doing a heater core like I did. Install some washers on the feed hose to the heater core to act as a restrictor. Trust me, heater cores on these aren't fun, and they're less fun when the core is swelled up from operating at ludicrous speed for extended periods.86 Lincoln Town Car (Galactica).
Originally posted by gadget73Just be careful racing people or you'll end up doing a heater core like I did. Install some washers on the feed hose to the heater core to act as a restrictor. Trust me, heater cores on these aren't fun, and they're less fun when the core is swelled up from operating at ludicrous speed for extended periods.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
