1991 Grand Marquis. Replacing the fuel system on this car because it sat for 11 years.
I can't get the fuel line to disconnect from the 3/8" line at the fuel pump. I had to cut the steel line on the pump assembly in order to get the tank out. I have 4 hours into this connector, and it won't give. Soaked it Deep Creep, blew it out, tried both the plastic and metal line disconnect tools. The line is loose, the clips are loose, and I have a little in and out play, but it will not release.
Any other ideas on getting it disconnected?
