Any 140 mpg speedo for sell?
  • Grand Marquis GT
    replied
    You idiots..
    It will read JUST FINE.
    Leave a comment:
  • 85crownHPP
    replied
    do they??? i just assumed that since the 140 has a wider sweep it would read way too fast... like it would read 140 when youre doing 85. maybe its got something inside the speedo to compensate.
    anyone know?? maybe i should pop one in mine and see hhmmm.... i dont want to risk breaking my gear indicator cable bracket
    Leave a comment:
  • p71towny
    replied
    I thought they would swap without a gear change. I think the speed at the cable should be the same rate in any box body, hence the need for a different gear for a rearend gear swap to keep the cable the same rate.
    Leave a comment:
  • Paul_
    replied
    Originally posted by 85crownLX
    the speedo cable comes right out, you just gotta find the sweet spot on the white clip holding it on and it will release. the reast is plug and play.. you might loose some options like the oil level warning light or your trip odometer but it is plaug and play.
    I think you will need a new speedo gear in the transmission to get it to read right.
    unless of course by some huge coincidence his car and the donor car have the same rear ends
    Leave a comment:
  • 85crownHPP
    replied
    Leave a comment:
  • NATEHAWK
    replied
    I got ur message pete and i might be buying one from you i been lookin at all the yards in my area and i cant find one.. How do you connect teh speedo cable or well disconnect it from your old speedo? And to all my car is a 1985.. So no mods or extra stuff for it to read the correct mph!
    Leave a comment:
  • 85crownHPP
    replied
    i just got 2 of them :slug:
    Leave a comment:
  • trwp72
    replied
    Speedo
    It just depends on what year your car is.. after 1990 (I think?) they were electric, before that they are speedo cable... just got to get the right kind for the right year.... Tom....
    Leave a comment:
  • Grand Marquis GT
    replied
    Direct bolt in, and plug in, and will work.
    Leave a comment:
  • NATEHAWK
    started a topic Any 140 mpg speedo for sell?
    So whatzup with the 140 mph speedo's? I want one but i was told it wouldnt work out right that i would have to mod it somehow? Is that true?Also even if i put it in will it give me a accurate speed reading??
