351w 5.8l Engine Bolt Torque Specs
    Found these and thought I might share....
    Torque Specs-351w 5.8L
    Always torque bolts in three equal increments
    Bolts or Parts Lube or Sealer Torque to:
    Main Caps Engine Oil 105 ft-lbs.
    Connecting Rod Bolts
    Engine Oil 45 ft-lbs.
    Cylinder Heads
    Engine oil (blind holes)
    Sealant (water jackets)
    85 ft-lbs.
    Rocker Arms Engine Oil 20 ft-lbs.
    Oil Pump Engine Oil 25 ft-lbs.
    Oil Pump Pick-up Thread Locker 20 ft-lbs.
    Oil Pan Engine Oil 15 ft-lbs.
    Camshaft Thrust Plate Thread Locker 10 ft-lbs.
    Cam Bolt (upper gear) Thread Locker 40 ft-lbs.
    Front Cover Engine Oil 25 ft-lbs.
    Intake Manifold
    (Cast Iron Heads)
    Non- Hardening Sealer 25 ft-lbs.
    Valve Cover Engine Oil 10 ft-lbs.
    Flexplate (Automatic)
    Flywheel (Clutch)
    Thread Locker 85 ft-lbs.
    Clutch Pressure Plate Thread Locker 35 ft-lbs.
    Centerbolt
    (Harmonic Damper)
    Thread Locker 90 ft-lbs.
    Bellhousing
    (Transmission to Block)
    sigpic1991 Crown Vic 351w 5.8L
