Missing Trim
    Missing Trim
    I have a '91 GM that I purchased recently. It looks like there is a piece of trim missing just under the rear window at the top of the trunk. There are small white clips running the length of the window. Does anyone know what this trim piece is called so I can replace it? Thanks....
    1991 Grey Grand Marquis LS Sedan
    61,000 Miles
    1998 F150 XLT 4X2 Flareside Fire Engine Red
    52,000 Miles
    http://www.cardomain.com/id/hdlogistics
    its called the bottom rear window trim peice..
    Go to a junkyard, and try to find one thats the same color as the rest of the trim...
      Thanks for the info. I'll check out the local wrecker for the piece.
      61,000 Miles
      52,000 Miles
        hmm
        i have a spare if you need one, just pay shipping
        SuperFord Profile
        Support safe sigs
        -sigs should not exceed 600 pixels wide
        -sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
        -Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
        -Total sig size should not exceed 60k
        Remember, only you can prevent sig abuse....
          Thanks for the offer Grimor. Since I'm in Canada, it might be an agro to import. I'll hit the local boneyard here to find one.
          61,000 Miles
          52,000 Miles
