my 1984 gm has a new battery, alternator, and voltage regulator. and yet the dam thing wont charge.. i have already returned to pep boys with the battery and alternator for testing.. they both tested good. so that is when i bought the voltage regulator but that didn't fix it.. all the wiring looks pretty poor but i don't know the wires should test as.. as far as i know the altornator could be wired wrong.. some one please help!!!
charging system help!!!
How's the connection at the battery? Did you clean the terminals? If that's good you're ground wire might not be gettin connection, down on the motor (I think).'89 Ford LTD Crown Vic - '92 Ford F-150 Custom -
'95 Ford Bronco XL -
sigpic :rebel:
the ground connection fom the battery to block looks pretty good.. i will still be adding an additional ground cable from the battery to the chassis.. And as for my battery terminals thay are clean and the clamps are 24k gold plated for optimum conduction of electrical curent flow.
thanks for all your help guys .. i removed the altornator for the 2ond time to have it tested, hopeing the first guy at the parts store tested it wrong . but it was good.. after re installing it i noticed a harness on the drivers side inner fender with a wire loose from it. the wire coroded from one of the harness pin crimps. so i jumped the wire to the wire connected to the matching pin on the other side fo the harness know everything works perfect :slug:
replace your grounds
SuperFord Profile
Support safe sigs
-sigs should not exceed 600 pixels wide
-sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
-Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
-Total sig size should not exceed 60k
Remember, only you can prevent sig abuse....
