I thought my starting problems would be solved after I installed my new alternator but things just can't be that easy for me. I have had the car not start and then crank up a few tries later. Usually when it doesn't start all the dash lights refuse to come on while starting or having the key at the on position. Come back a few minutes later and it starts? I also had the car cut all power twice while driving at night, it came back on after less than a second but it was noticeable. I installed a new starter solenoid yesterday and the car wouldn't start the first time I tried it. I jumped it with the zephyr and grounded the jumper cable to then engine and not the battery - it started. Pull the jumper cables and it starts fine on its own again.
I'm going to buy some new battery cables today and hope that solves my problem. Anyway to test the starter?
