Heater Core Hoses
    Heater Core Hoses
    Where can I buy Goodyear heater core hoses?
    I'm not sure if these are what you are going for, or what the diameter is...
    http://store.summitracing.com/defaul...=egnsearch.asp
      I'm looking for stock replacement formed hoses that are of higher quality than Advanced, NAPA, etc.
        Heater Hoses....
        RustyShackelford
        Thanks Mang!! I have been looking all over for the Goodyear heater hoses for my '84 LTD.... Tom...
          autozone sells goodyear hoses..........what's wrong with the gates hoses?
            I keep blowing them out, or creating a pin whole leak. I've had 3 failures un the last year, and I bought all of them new. The hoses are so fresh, that I can easily remove it from the heater core (and that is supposed to be a bitch)
            Thanks
              Try using the red heater hose it made alot better.. It has about three layers of diffrent material. I ordered a big roll of it off ebay for about $15
              The Best
                I would but mine need to be be formed. They both make two turns greater than 90degrees and both are only about 1 foot in length.
                  Hoses...
                  The Goodyear hoses are silicone hoses... and you know me and getting the car original... That is what the state always ordered on their cars... I even have them on my '91.... (Altho those are green for some reason... ugly!) Besides the fact that they last forever.. I don't know why anyone would take them off the car.... idiots... My car went to the shop when it was the Fire Chiefs car.. they replaced the hoses... We asked them why.. they said they were over 50,000 miles on them... I told them well duh... did you know those are silicone "Lifetime" hoses??? The guy was like, uh, no.... so we asked for them back... they had already THROWN them AWAY.... It took me another 2 years to find some on a wrecked cruiser....
                  Tom!
                    did you try the oem hoses blaze? towncars use unique heater hoses......both the heater lines go thru pipes under the upper intake....i was able to get an aftermarket hose for the pump to pipe, but not the 3 rear heater hoses.......i picked those up from ford. the factory hoses last a long time btw
                      Here is where I have gotten them, these are the 2 hoses in the back of the engine. I did the Napa Hoses first, Advanced hoses second, and Motorcraft hoses last.
                      All cruble and die in my path...so I need those silicone ones.
                      I wasn't sure if they were available at all from goodyear. I'm not even sure if they are stock or not...that is sad, I've bought three of them in the last year and I can't remember if they are stock or not. :nonono:
                      Well, both have a Z shape to them. The length of the middle strait is about 8"-10"
                        What kind of RPM are you turning with that motor?
                          5300-5500rpm. I don't free rev it past 4500rpm, and burnouts are usually low rpms (<3000rpm).
                            I blew mine apart many times running 5400-5600. Restrictors and an underdrive crank pulley would help. Damn grandma cars..
                              i was just thinkin about that........did you have the restrictor in the one heater hose? it's a piece of metal with a small hose in it.........have heard of heater cores blowing at high rpm without it
