I'll be trying to pull OBD1 codes for the first time myself, soon
So following this with some interest.
It'll be hilarious if these newer, gizmo-filled cars were enabled with wi-fi and send you an email at work when your car throws an error code while your son's driving it!
Then follow illustrations of the probable cause in high-res to your inbox, and advertisers can pay to give you annoying, flashing animated quotes to do the repair. "we heard Mr Arnest that you recently had a check engine light, let us fix it for less!"
Goofiness aside, I'll second that hills kill gas mileage; I drove down skyline drive last month and got nothing like the 25mpg I was getting on the flat beltway in baltimore! Nothing at all like it
I am also curious: i was reading up on O2 sensors (I replaced one of them for 'shits and giggles' already, where is the second one however...? The one I changed was right off the driver side exhaust beneath the spark plugs).
I read that they only function at 600F. Now of course, the overall engine temperature is 195F, if the cooling system and thermostat do their jobs! And it takes my car at least 5 minutes to get up to full temperature. But how long does it take for the exhaust only to get to 600F? And can I presume that until it does heat up, the O2 sensor is for all intents and purposes inactive and your fuel economy will be hell?
