wheelbase differences?
    Is the wagon WB any different from the sedan? Looking at parking brake cables for my disc swap.
    good question .. im not sure
      Nope, wheelbase is the same for all CV/GM. (4dr, 2dr, Wagon) The wagon is, however, a couple inches or so longer. I'd have to dig out a brochure to get the exact numbers. I can if you want.
      '95 Ford Bronco XL -
      sigpic :rebel:
        kinda off topic but does my 89 towncar have a 8.8 inch rearend?
          Yessir.
            and semi back on topic, the Towncar wheelbase is like 3" longer.
              Yeah, I know about the TC, just wondering if there was a difference for the vics.
                Actually I'd have figured the wagon would have a longer wheelbase, so that was a good question.
                  People think the 2 doors are shorter, too.
                  sigpic :rebel:
