How often should you change the tranny fluid and filter on an AOD? I have a '91 GM and I'm looking to make my first change.
Tranny Fluid
Tranny Fluid
1991 Grey Grand Marquis LS Sedan
61,000 Miles
1998 F150 XLT 4X2 Flareside Fire Engine Red
52,000 Miles
http://www.cardomain.com/id/hdlogisticsTags: None
Well after seeing that, I'll be doing a change on the weekend.1991 Grey Grand Marquis LS Sedan
61,000 Miles
52,000 Miles
Just changed my tranny fluid & found the plastic plug in the pan. I guess that means that the fluid had never been changed since '91. The fluid looked a little dark but was shifting ok. Thought I'd better change it just in case. Seems to shift a bit smoother now. :jumpin:1991 Grey Grand Marquis LS Sedan
61,000 Miles
52,000 Miles
i change my transmission fluid every 25.000 miles or two years, whichever comes first.........i use the same routine for cooling system service too
scott
