can i get a shift kit for a towncar?
    i want to get a shift kit to compliment my 3.73 gears and HO conversion (when it gets done)? any recommendations? and how hard is it to put one in?
    Of course. Add a Mustang HO governor while you are at it.
      The TransGo shift kit is a good kit.
      Its inexpensive, and you can do it while you are doing a filter/fluid change.
      If Jason can install one, anyone can
        is this a good one that will fit?
        http://cgi.ebay.com/ebaymotors/TRANS...spagenameZWDVW
          Two people here use the transgo HP kit and love it.
          the cheaper one to use is the regular transgo kit, PM 88grandmarq for details...
            I still got a shift kit I need to stuff in GL. I got lots of time but at the same time, no time. I don't get it.
              I need to pick one up myself. I already have the HO governor sitting in the trunk where it's been for months now. I'll probably get the cheaper kit, use my HO governor and call it good. I don't really need the pump-shift action of the 2 stage kit or the 5200 rpm governor.
                Sorry for the hijack. Who has the Transgo HP kits installed on their cars? How does it feel/shift?
                '90 Mercury Grand Marquis GS
                5.4L swap coming soon.
