Seafoam Question
  • trife86
    replied
    i know im really gravediggin this thread, but i finnaly got around to use some seafoam today, i took it easy for a test cause i dunno anyone that ever used it except people online. i used like 30% through the vacuum and the rest i just dumped into the gas tank. let it sit for about a half hour, only smoked for like 2min after that was real heavy at first. Made the engine a bit smoother but thats all. I guess after next oil change ill use a hole can in the vacuum that smoke is hilarious
    Leave a comment:
  • grimor
    replied
    Originally posted by RustyShackelford
    Also, does anyone use one of those Tornado air directors? The theory seems well enough, but they are $60 or so I think. Again, thanks in advance. -Rusty
    it's bs, 1 the air will not recieve any "swirl" by the time it gets to your intake. The air is compressed before ignition and is pretty much stationary.
    Leave a comment:
  • p71towny
    replied
    A buddy of mine gave me a tornado, I dunno if it really does shit. I never noticed anything. Good to see a king of the hill fan. Dale gribble
    Leave a comment:
  • RustyShackelford
    replied
    thanks for the pics. I'll give a try with the Deep Creep first, then jazz it up with the regular stuff. Then a can of Restore and we'll see. On a seperate note... what kind of oil filters are you all using? I thought about getting a K&N oil filter because it says that it contains some sort of check valve that keeps oil up in the pistons for better start-up protection; supposedly. I usually use a Fram, although I currently am using one of the new Napa ones with the spin fins or something. Also, does anyone use one of those Tornado air directors? The theory seems well enough, but they are $60 or so I think. Again, thanks in advance. -Rusty
    Leave a comment:
  • Sambos86LTD
    replied
    Leave a comment:
  • grimor
    replied
    sea froam
    bah, do it right, do the pcv vavle. Replace your PCV valve with one that has the 2 hose connectors and buy a little bit of vac line.. then you can hook up the hose and pcv valve the right way and have the extra vac line come off the top for sea foam.. then you can just cap that line and never have to reach in the back to seafoam again....
    I think this made sense
    Leave a comment:
  • Grand Marquis GT
    replied
    right off the booster.
    a huge hose.
    Leave a comment:
  • RustyShackelford
    replied
    well the Deep Creep is made by Sea-foam as well.
    http://www.seafoamsales.com/deepCreepConsumer.htm
    I have used other throttle-body spray cleaners before, and I guess it helped, but another question, where is the brake booster cable (supposedly right off the booster)?
    Leave a comment:
  • Grand Marquis GT
    replied
    Well, that PCV is a bastard to get to. Its actually in the lower intake itself, passenger side...
    Seafoam rocks...most people feed it in thru their brake booster line...
    Seafoam is teh win! I used it... But i dunno about this other stuff you talk of...
    Good luck, and happy hot rodding!
    Leave a comment:
  • RustyShackelford
    started a topic Seafoam Question
    Seafoam Question
    I have a question about Sea-foam ( and kind of about a PCV valve). I own an '89 Marquis and I don't really know where the PCV valve is. I do know that it is not in the valve covers. I think that it is behind the intake, but I haven't really felt around that much for it. I probably should grab around there so that I can use a can of sea-foam in it. I have a can of the Deep Creep that I was going to use on the Intake throttle plate and on the tube that runs from the neck of the engine oil fill- to - the intake. Has anyone used the Deep Creep on their car and the regular Sea-foam? I just changed the plugs, wires, cap and rotor. I hoped all of the new gear would do a little more for the engine, but maybe cleaning it out would do the trick.
