I'm not the sharpest tool in the shed, but driving around town in D looks expensive (a rebuilt AOD comes to mind). Is everyone sure I should drive in D for the best performance (off the line, around town and leave OD for the highway)? My old '89 TC felt stronger in D than my GM. The TC had the P-R-N-OD-D-2-1 gear selection. My GM is missing 1 if it matters.
P-R-N-OD-D-2, should I drive in "D"?
I never worry about gas. I take public transportation to work during the week ($16.50 unlimited use, bus and train). The price of gas could have went up to $20/gallon, I'd still drive. (If you want an omelet, you have to break an egg). I also have a gas card and I pay it once a month...
. I'm just worried about killing my AOD.
'90 Mercury Grand Marquis GS
5.4L swap coming soon.
D is good because is keeps you in the 1st three gears. Fourth is overdrive and is not designed for performance loads. D will only prevent you from going into 4th, it has no side effects or anything like that. Like he said, <50mph and D is fine.
I'n my personal opinion I like cruising in 4th at 40mph though. Nothing like cruising at 1000rpm
But when I am hot rodding around I keep it out of OD if possible. My new transmission that is soon to be re-installed in my car has P-R-N-OD-2-1 shift pattern.
yea, if your engine is in good enough shape to cruise around in od at 40 :P
bastage
hrm, that shick in josh gracins new video is yummyGMNRadio DJ, Podcast Co-Host
95 S10 93 Accord
stock shift pattern for all AOD should be P-R-N-OD-D-1 modded ones could be near anything. Never seen an AOD with OD-D-2-1
Under 50, stay in D and you'll be fine. you're actually more likely to cook it driving around in OD at 40 mph than driving in D.86 Lincoln Town Car (Galactica).
Hate to differ, but Towncars do not have P-R-N-OD-D-2-1. They have the same P-R-N-OD-D-1 pattern that every AOD has. The shift selector on the side of the trans physically doesn't have another detent, so it just can't do that. This is somewhat annoying, but really handy if you're gonna drop an AOD in something that used to have a 3 speed auto as it has the same number of clicks.
This is my 86 dash.
http://www.gadget73.lunarpages.net/i...ge_cluster.jpg
And this is an 89.
http://members.cox.net/werecar/instrument.jpg86 Lincoln Town Car (Galactica).
So if you spend most of your time drivin over 50mph you should do it in Overdrive?
