hey where's a good place to get heads rebuilt. The ones I got for my HO conversion need new valve seals, milling, media blasting and a little porting on the exhaust bumps. I do not want to attempt to rebuild them myself as a 1st time engine builder. Any suggestions?
where to get heads rebuilt
Re: where to get heads rebuilt
where u at? i can get em done at a reasonable priceOriginally posted by 89LincolnTWNcarhey where's a good place to get heads rebuilt. The ones I got for my HO conversion need new valve seals, milling, media blasting and a little porting on the exhaust bumps. I do not want to attempt to rebuild them myself as a 1st time engine builder. Any suggestions?
scott
carquest says $6 per valve seal, $30 per head for milling, $20 for cleaning. sounds decent to me.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
The place around here does them for $125 each I think. Thats just basic cleanup, cut the valve seats, valve faces, and install new seals. I guess he laps the valves but I won't swear to it. Not sure what they'd want for porting or milling.
I did both of mine for a grand cost of $65 in parts (new exhaust valves) and a case of Coors Light. Not ported or anything fancy, but considering I got it done for just about nothing I'm not going to complain.86 Lincoln Town Car (Galactica).
