I think it's getting close to the time to replace the shocks on my 91 Gm. The ride is starting to float more than usual. Any ideas on the best shocks for the big boxes?
I use Variable assist cargo coils for both front and rear shocks. Makes the ride nice, a little on the stiffer side and they look pretty cool too
SuperFord Profile Support safe sigs
-sigs should not exceed 600 pixels wide
-sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
-Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
-Total sig size should not exceed 60k Remember, only you can prevent sig abuse....
Summit has a coil -over kit. you have a crossmember that welds between the frame rails http://store.summitracing.com/defaul...4000K&x=19&y=9
Speedway Motors has all the componets to do it , with springs up to 750# might go with the bilstines http://www.speedwaymotors.com/xq/asp...st_display.htm
(check them out for 5.0 parts i got a set of 4340 forged connecting rods from them for $80 the same ones Ford wants over $300 for
iI can do all the welding required and we have a very competent machine shop right next to us at work
also going to try to use Wilwood Forged Dynalite 4-piston calipers up front it will cost under $400 for the calipers, rotor hats,and rotors. thats if i can modify the 92+spindle to accept the brackets
