Picked up a B&M Pro Stick shifter today with the AOD brackets and a new shift arm.
New shifter
New shifter
http://www.grandmarq.net/vb/showthread.php?t=5634Tags: None
Noice. Thats bad ass.1989 Grand Marquis LS
i guess my interior is going to have a "Ford 80's interior meets new aluminum racer goodness" look to ithttp://secondhandracing.com/Home.aspx
awesome! get er done!
DuceAnAHalf, so how's the feeling with the floor shifter? I'm seriously considering doing that conversion on my TC, although I'm looking at the Lokar shifters as they bolt directly on the tranny and all the linkage is as hard as it can get (no cables to snap and kink). Also considering I have the stock split-bench seats (and there's no way in the world I'm giving them up for buckets) what length of a stick do you think will be comfortable for shifting?
This shifter is short , whifting it feels like using a transfer case lever in an old jeep, i have to lean forward to shift it. id say get a tape measure and measure from the floor to where you feel is a comfortable height and then find a shifter about that size.http://secondhandracing.com/Home.aspx
I dont think you have to drop the colum, when i removed mine i think the colum was up but i had no dash in it. It takes a lot of beating and force to get the old linkage out of the vehiclehttp://secondhandracing.com/Home.aspx
How easy is the removal of the old linkage in the streering column, do I have to drop it to get the stuff out? Anything I should leave (not remove) there?
