Nice Mass Air write up
    Somone who knows more about mass air converting should take a look at this write up I found on ford muscle. They did it to an 89' F-150 but minus adding an oxygen sensor the process should be the same?
    http://www.fordmuscle.com/archives/2...sion/index.php
    -Matt
    Eh, similar-ish but the re-pinning of the ECM is different because of the batch-fire that trucks use. I'd go by this one, which was written for a Mark VII. Its about as identical as you'll find.
    http://www.lincolnsonline.com/article77.html
      Yea, I wasn't sure how similar the setups were but it was very detailed so I thought I should post it up in case it would work for boxes too.
      -Matt
        MAF swap is easy on any SEFI car.... only have to add 2 wires to the harness and solder 2 more to exsisting wires.
          Yep, Mustangs are 2 hours tops from start to finish. Including the actual MAF install.
          A Vic would be easier to wire...
            Yeah.... ECM harnss on the CV/GM is outside the firewall, so its super easy.
