Tuning SD for extensive mods.
    You should be fine,You are leaving about ten HP on the table w/o chip/disabling of EGR but that can be addressed too.And if you are a do it yourselfer and on a budget you can installa potentiometer on the map signal return and tune a speed density set up even heavily modded to an extent.
    That came from a local mustang builder. Anyone know more about this? Might benefit you SD guys so you can go with a bigger cam.
    If you find out anything, let me know. I'm told my (stock) cam is going to be hard for the SD computer to handle.
    What do you think, Mercracer?
      wait, stock cams are hard for speed density to deal with? wha?
        You are going to run a Lincoln SD computer with your Explorer motor, aren't you??
          In other words this means that you can take use a continuous variable switch (ie dimmer switch) and use that to tune your signal form the sensor. Will work untill your signal is too weak, because the potentiometer will not step up the signal, only step it down.
            I posted this a while ago;
            The TwEECer is the best option for SD tuning. TwEECer RT has a data logger so you can monitor 02 and similar functions.
            However only the Mustang DA1 ECM and mark 7 D9S ECM's are compatible with the TwEECer.
            The TwEECer is an adapter which connects to the J3 service port of an 87-95 Mustang EEC-IV PCM, giving you the ability to substitute parameters in the calibration data with parameters that match the modifications which you have made to your engine combo. So as you add performance to your car, you can easily match the EEC to your combo.
            I am not familiar with the potentiometer trick, but i have heard about it being done. Basically you need something like a TwEECer to monitor the MAP singals.
              The ECM only has a problem when Manifold vaccum drops below 17 inches at idle, this is why cam duration and lobe seperation are critical.
                I didn't have any problems with a stock cam and ported heads and a bunch of other work with SD. With an aftermarket cam and heads, I'm having some issues.
                That map thing is interesting. Might have to look at the signal and see how bad it is. My wagon just barely idles. Pretty tempermental.
                  Like I said Mike, if the manifold vaccum is below 17 inches at idle the car will run like poo.
                  At less than 17 inches of vaccum, the ECM assumes the motor is under load and starts changing the fuel MAP (dumping fuel in the motor).
                    I'm talking about the Explorer cam. I'm gonna run it either way and hope for the best. Worst case scenario, I'll bust my ass and figure out how to tune SD.
                      Explorer cam is fine.........it's is basically the same duration as the Mustang/HO cam but has a tad less lift (.422" Vs. .444" )
                        Yeah, gotta get a gauge and check out the vacuum. Also need to check the FP. The cam I got has a 114* lobe separation 212/218 @. 050 lift. 512/512. Shouldn't really cause too many problems. Though it does say compatible with OBD4 ( think they meant EEC-IV)
                          is that the TFS stage one cam, Mike?
                          the specs sound familiar.
                            +The TFS stge 1 does not have that much lift on the exhaust side
                              Nope, Comp Cams XE264. Liked the specs better than the TFS.
