Hey guys I spent the day getting the H-Pipe on and the sensors hooked up. I had to buy a new one for the passenger side but the drivers cord reached. I reset the EEC also and I got the check engine light to go away. Now when I start it up and let it idle it runs really rough (chugging like a choo choo right when it starts moving) and when I put it in drive it almost cuts off on some strokes. I'm thinking timing is the only other thing, I KNOW WHERE THE SPOUT CONNECTOR IS NOW :woot: , The thing I'm confused about is that I NEVER TOUCHED THE TIMING!!!!
UPDATE on LTC: O2's and h-pipe on
How did you manage to remove the intake without pulling the distributor? Just seems like it would be a big PITA to have it in the way.
ECM might need to re-learn a bit. You're gonna have to drive it a little to see if it clears up. I'd also check your vacuum lines to make sure everything is connected and/or capped as needed. If after driving 5-10 miles it hasn't changed any, pull the codes and see what it has to say.86 Lincoln Town Car (Galactica).
I just worked the intake around the distributor. I'm afraid to drive it its soo bad, i don't want to hurt anything.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
I just remembered I turned the engine while I was trying to get the crank bolt out, and I know I had it close to TDC on piston 1 but its probably off. THAT"S how I changed the timing :guns: :morons:1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
If the distributor was in, and has not been rotated, you can spin the motor all day long without affecting the timing. It would function just the same as if the engine was running.86 Lincoln Town Car (Galactica).
unless it was cranked without the cam, lol
did ya pull the timing chain?Originally posted by marquismanunless it was cranked without the cam, lol2000 Grand Marquis LS
Mercury Owners Group member
