BELTS
    BELTS
    I'm thinkinking of getting rid of the a/c unit,is there a serpintine belt,that wil fit on the air pump,and the crank.If so does anyone know teh number
    It's around somewhere. I haven't put on on mine yet, besides I have a underdrive crank pulley so mine would be shorter.
      How much of a gain is taking it off?
      1989 LTD Crown Victoria LX.
      -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
      4 Door Muscle
      Supermotors
        Air conditioning comes in handy during the summer. Why would you want to get rid of it? You'll be kicking yourself in the ass on those humid, mid 90-degree days sitting in traffic.
        '90 Mercury Grand Marquis GS
        5.4L swap coming soon.
          my AC was shot - I am running now with no AC. Ill go check the number on the belt for ya
            If my compressor was shot, Id have ditched my ac long ago, but since it works I'll do what I can to keep it nice for a long time.
              Depending where you live, and the condition of the AC, you might want to re-consider it. Also, if you live in a non-emissions state, you can prolly dump that air pump and all the mess on that side of the engine. Cleans it up nicely.
                +1 on dumping the air pump, its easy to do and you'll pass inspections without it if you warm up your car before you take it in
                  unless you have a visual inspection :cuss:
                    I think it's a 500K6 for A/C delete and a 560K6 for smog pump delete. Someone correct me if I'm wrong.
                    Project \"Fire and Ice\":
                    1989 LTC
                    My worst enemies are those who presume me to be harmless. They cannot imagine how much I resent and disdain them, or just how great a threat they would face if I could get at them. Everything in their behavior speaks of insult and presumptuousness, and for now it is all I can do to make constructive use of my anger toward them. At this time, I just make a list of them and keep a watch on. Some day, with the help of time, space, and circumstance, I will be able to humiliate them properly - not in a manner they would enjoy, but in a style calculated to make them wish that they had never been born.
                    Anton Szandor LaVey
                      I used NAPA belt - 25-060435
                        wouldent a ribed tention pully be nessasary?
                          Ideally yes, but good luck finding one :cuss: I ended up using one from some early 80's Cougar, but was dumb enough to not pay attention of the particular model of the car - now that the pulley's bearings have started to squeel I cannot find a replacement! Anyhow, belt is a Gatorback for a 2.3L Ford or Mazda, pic I'll post later when I find one.
