when i go 351, i'm going with the sefi 351(would be easier than converting my fuel system to accept a carb. i know the efi 351's have a taller intake than the 302 and won't clear a stock hood, but i'm going to be solving that with prob. 3 inch cowl induction setup. my plan is to grab one and build it up over the next two years. now
1. are there any good 351w parts sites(frpp's site does not work on my pc,lol)
2. can the mustang 19lb injectors be used on a 351w?
3. will i have to make any alterations to my fuel system, even though they are both efi?
4. are the 5.8efi's speed density or mass air?
5. around how much to have the heads ported, plolished, and the motor balanced?
6. will i have to get an adapter for the tv cable? i know the aod will bolt up to the 351, but i also plan on replacing the stock upper and lower intake with an aftermarket setup
7. any excellent heads out there for 351's?
8. cam reccomendations? ithe car will be my dd, and an occasional run at ne dragway
9. iis it possible to do a 3g conversion on a 351? i'd rather just have a reliable lug and not a fire hazard plug,lol
since this will be over a couple of years, i don't nescarilly have a miniscule budget. basically i want this thing to be a monster of sorts. also when i get ready to install the motor, beforehand i'm going to steamclean the front end(i'm going to disassemble everything cept the fenders to make the removal and installation smoother. i'm also before the motor goes in, i'm going to do the 98+steering upgrade. that way, i have tons o room to work with. i know i need the newer steering box and someone said that i would need a new pitman arm as well when i do that. i also plan on replacing all the balljoints and the springs. i also plan on getting pi shocks at all 4 corners.
i could go with the ho conversion, but i think i would see more power gains from the beefed up 351, and an efi 351 in a box would be unique as i do not know of anyone that has done it. i also know theres a wealth of knowledge floating round this board and i intend to use it.
thanks in advance guys!
