Dumb vin/ EEC code Q...
It didn't... only got 2 codes....both for the recirc air that is disconnected. Nothing for the MAP or ECT. I'm going to swap the map with th eone out of my 87 and see how it does. I also need to redo the setup for the vacuum lines to get my cruise working again. I'll have to get creative.
Originally posted by CaptainWackyVin code "E" is for the Mustang/Capri HO.
The Mark 7 had Vin code "M".
ok... after doing some more research, it appears 87 year model HO motors were VIN "M". 88 and newer HO motors were VIN "E"
I dont really think it makes a difference when pulling codes.
Leave a comment:
Leave a comment:
HO motor Vin # is "E"
87-90 SD ECM's are all pretty much the same, in 91 Ford went to a 3 digit trouble code system.
Leave a comment:
Can't remember if it makes any difference with a code reader, but what's the engine code for a Mark 7? I've got an Auto xray xp240 and need to check the codes on the wagon...Guess I gotta find the year of the ECM I'm using also....Tags: None
Leave a comment:
