i gotta replace the water pump on the vic. since i have no clue for the most part about the cars history, i should probably do the timing chain while i have the front of the motor undone lol. knowing my luck i'd just replace the water pump and two weeks later the chain would break. any good and cheap timing chains? i don't need nothin fancy.
prob should do the timing chain too, need reccomendations
Gear drive.
I got mine new for $100
Yea, since you got it apart alreadyOriginally posted by p71townyCloyes double roller, and while your at it a cam as well, and intake, and, ........... So it begins :evil:
2000 Grand Marquis LS
Mercury Owners Group member
Where'd you get it for that price? Im trying to be low budget and that would be about what Id be willing to spend for my timing setup. I've been looking around at some nice double roller sets for about $80 in summit, jegs, and speedway.Gear drive. I got mine new for $100Chris - A 20th Century Man \m/ ^.^ \m/
$100?! wow I paid just under $40 for my SA gear timing gear and chain set off ebay.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Speedway motors. you have to cut out the ridge in the timing cover. i had to have one of the little gear axels shortened. did not take much just walk to the machinists and have him throw it in the latheOriginally posted by p71townyWhere'd you get it for that price? Im trying to be low budget and that would be about what Id be willing to spend for my timing setup. I've been looking around at some nice double roller sets for about $80 in summit, jegs, and speedway.Gear drive. I got mine new for $100http://secondhandracing.com/Home.aspx
all factory hydraulic roller cam motors got a double roller timing chain. Yours might be worn and a little loose, but I doubt it will break any time soon.
pulling the timing cover requires you pull the balancer, which can be a pain to get off if the nut has never been off before and you dont have access to a big impact gun. it also requires you borrow, rent or buy a balancer puller. sealing the oil pan where the timing cover attaches can be a pain too.
my vote is dont pull the timing cover unless you have to, change the water pump and be happy.
hmm, good points. i don't have an impact gun either. even if i did, everytime we plug the air compressor in it blows the fuse in the house :geek2: i'll prob just do the pump then.
pump
hoses
thermostat
fan clutch
sound about right or am i missing somethinSave a seal, club a liberal.
Hose clamps!!!!
:drug:
Also make sure you get the gaskets for the thermostat and water pump too if they dont come with em. I like to use some RTV as a sealer too, thats just me tho. And while you have it apart you could get new belts too!!
$300?????
for a water pump replacement?
I got a good pump for $27 with a $6 core charge
Or is it a true "wishlist" and has some goodies for the car?
i'm with eric...........make sure to replace all the coolant hoses, the fan clutch, radiator cap, water pump, vc gaskets,full tune up and seafoam, belts, and drive it
