Sounds like a chicken under my hood!
    Today I went out to a basketball game and noticed a ticking sound when I accelerate. I thought it was the timing so I messed with it but it isnt related to that at all.
    I just got back from peeping under the hood, it isn my fan hitting anything. I checked the oil and coolant, everything is Ok. But when I am at the passenger rear side of the engine the ticking becomes apparent. The sound only happens when the rpms raise, but you can hear a tick at idle. I dont have any idea what that could be but it just started doing it. I'm thinking, maybe there is something wrong with my heads (springs, valves, or rockers). If anyone has any ideas that would help, I would much appreciate it.
    Dude, did u ever change the springs with the cam?
      Lifters, could be improper pushrod length....etc..
        Do you have headers or exhaust manifolds? A cracked exhaust manifold will give you a ticking sound too.
          Yea it sounds like an exhaust leak, especially if it's louder with the engine under load. Load=more backpressure=louder sound
          Nick
          88 Colony Park LS
            I was also thinking exhaust leak. Could also be a cracked thermactor pipe if that is still back there, or a leak at whatever you used to block it off.
              yeah, check both the smog crossover pipe going to the heads, and the pip/check valve going to the cats.
                I have no smog system on the car now, I blocked off the ports with the fitting flipped around. Could really bad gas cause this? This all happened after I filled it up with a tank of shell 87. I trust shell around here, but shit happens and maybe they had bad gas. It sounds like a bad ping except louder which is why I went to adjust the timing first. And it all happens when the engine is under a load. What do you guys think?
                  when i did the intake on my old mans i had that ticking and/ knock but i put in some winns engine tune up, and it went away in 15min, and changed the oil and its all good now.
                    I tried some seafoam, octane booster and dry gas in the tank and it didnt help at all. You can hear a slight ticking near the heads. I think I might want to rebuild my roller block now.
                      Valve ticks are not anything to worry about. I'd still be more inclined to say its an exhaust leak or a leak at the blockoff plates for the smog junk.
                        If it is a valve tick, I am very worried as it is very loud. My car runs the same tho. I just dont understand how it just started happening.
                          i would think that it is the rocker, sounds like exactly the same thing happening to a couple of cars i know about.
                            I'm popping the valve covers this weekend, I think I wont be very pleased to see whats wrong
                              Pulled off the valve covers today. Nothing is wrong with the top end. I had my pop help me and we narrowed the banging sound to around the drivers side of the bellhousing. I'm gonna pull the inspection plate next. When the car is cold, the banging isnt as frequent. When it warms up the banging happens upon any slight acceleration. Reving it high and letting it go back down to idle also causes it to bang. So hopefully there is just something in the bellhousing. Or could my transmission be going out?
