Hi All,
I need help from some experts:
I want to install a B&M #70273 transmission oil cooler in my 91 Grand Marquis, in series with the radiator cooler.
But I want to keep the 5/16" flared steel tubing I now have and just extend it to connect to the cooler's 1/2" female NPT pipe outlets. ( I don't want to use rubber hoses ).
To do this I would buy 2 pieces of 5/16" steel tubing with the fittings already on both ends and bend them.
The problem is:
I can't seem to find 5/16" flared to 1/2" NPT adapters (to screw on to the cooler outputs).
I also can't find a 5/16" to 5/16" flared tubing coupler (to connect from one cooler output to the existing return line).
Can anyone please help, or give me an alternative?
Thanks much,
91gmblack
The problem is:
Thanks much,
91gmblack
