rough idle problem found
    I drove the lincoln around the block after replacing every vacuum line and its a fuel injector. #6 is bad and fuel was squirting out the top of it and pooling in the lower intake runner. SO I'm going to buy some new injectors and change the fuel filter.
    Would you like me to send one to you? They have new Orings on them already.
      Yay!!!!
        You have a pm Blaze
          dammused parts......u need another injector man?
            yeah I think I only need one. I just want this car to work I've had the upper intake off like 6 times this month, lol. At LEAST I found the problem. I drove her up the block and she was smooth as glass after idle RPM.
              Most of the time you can just replace those O rings to stop the leak. The injectors don't usually fail and leak, they simply don't fire or have a bad spray pattern. Put some lube on the O ring before installing them. This exact thing was what caught my car on fire, so be careful with that shit.
