Anybody have any experience with the o-ringed thermostat housings?
    Has anyone used one? If so, did you like it, or did you go back to using a normal gasket? I'm thinking before I go hog wild on hoses, I'd pick one up, if reviews are favorable of course.
    Save a seal, club a liberal.
    I hear they suck.
      never had a problem with the one on the town car or chevelle. I just use a little rtv and away I go.
        chrome housings are teh evil and leak like a pig over time. IIRC I had an Oringed one on me chebby for a year or two but it leaked. I put a good ol iron housing on there and never leaked a drop since.
        2004 Marauder M79 90K miles Jmod!! 14.85 @95.63
        2004 Crown Vic LX 135K Silver Birch Light flint leather FMX1 04 P-71 PCM swap 04 P-71 Airbox and Zip tube "$100 MZT" 01 F-250 70 MM TB 21mm swaybar wood steering wheel BH headlight relay
          yup, this is true.
            So gasket it is. Thanks guys!
              I know justin ran an o-ring one for awhile, never complained..
              But of course, working in a parts store, I heard a lot from my customers, ASE certified mechanics
                when i first did my carb swap we used a chrome water neck from the parts store that used an o-ring seal. I've reused it a few times and its held up fine, no leaks.
                '80 Town Coupé
                  i never cared much for them......they leak over time
                    I've had generally poor luck with shiny bolt-on crap like that. Drop the stocker in a bead blaster and it'll be fine. Or just wire brush it and paint with aluminum spray paint.
                      hhmm... I have one of those chrome Oring necks in my trunk Ive been meaning to install... now Im thining twice.
                      I dont wanna have to change it back, that bypass hose is a bitch! I might as well replace it if I do, its going on 6 years old.
                        Yeah, replace the bypass hose when you do the t-stat. Screw trying to get that thing off there, just hack it and be done. They're cheap enough. Put a bit of that synthetic super lube stuff in the end of the hose and it'll make it easier to get apart next time.
