Noises
    Noises
    Alright well I thought it was the airpump but it wasn't. There is this like scratchy griny noise. Off and on.. chUrr. .chUrrr. chUrrr....... chUrr.. What the hell is that.
    There is also a buzzing noise coming from under the diver side fender. It kinda sounds like an electrical buzz.:ashamed:
    And if you unplug the spark plugs one by one, will knocking go away comeplety if it's a piston? (If you have all the cyl with bad pistons knocking)
    1989 LTD Crown Victoria LX.
    -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
    4 Door Muscle
    Supermotors
    It wasn't buzzing so I didn't get that.
    4 Door Muscle
    Supermotors
      Sounds like a dead bearing in one of the accessories. Pull the belts off and spin the accessories by hand. If its that loud, you'll feel/hear it spinning stuff by hand. Alt on my truck failed like that, made a horrible racket. My guess would be alternator, idler/tensioner pulley, or AC clutch.
        When spinning by hand my A/C compressor's clutch used to give out a scratching sound, was due to some surface rust though, no bad bearings.
        About the electric buzzing noise, where's your ignition coil? My MSD coil gives out a sound that can drive you crazy if you pay it too much attention, so I just ignore it
          Youz crazy manG!~
          '95 Ford Bronco XL -
          sigpic :rebel:
            Yeah, I listened to both sound clips..... the first one sounds like a bearing noise, I would guess either the A/C belt tensioner, water pump bearing or Alternator bearing.
              I think it's the AC. When I installed the new belt it was too loose at first and I didn't hear the noise. Than I tightened it up and it came back. I didn't think anything of it till now, that it happened like that. Could I use the bearing from my air pump for the AC and or waterpump?
              4 Door Muscle
              Supermotors
                No. The AC clutch has to be replaced, or the water pump needs to be replaced. Check the idler pulley. They fail more often than AC clutches do, and they're a lot cheaper.
                  Is that the little on that is connected to the same belt as the AC?
                  4 Door Muscle
                  Supermotors
                    Yep, the small flat pulley on a stamped steel swing arm - two bolts hold it to your A/C bracketry.
                      Alright. That's what I thought it was till someone suggested the AC. Couldn't really tell where it was coming from. I'm sure it's that than. Sounded more in that direction. I'll check it out tomorrow. Do I need a new one or can i just lube it up or something?
                      4 Door Muscle
                      Supermotors
                        I took off both belts. Still makes the noise.
                        :stfub:
                        4 Door Muscle
                        Supermotors
                          Well I've come to a conclusion.
                          There is a cat in my motor. It knocks it's skull on the block and scratches at it. It hisses at me and it shall soon die.
                          end of story.
                          4 Door Muscle
                          Supermotors
                            Maybe the starter is fucked up and the noise is the starter drive scraping on the flexplate. Or one of those dust shields around the bellhousing is crushed and rubbing the flexplate. Long bolt rubbing somewhere, the timing pointer bent inward and rubbing on the balancer. hard to say.
                              My starter gear was flopping out and when it hit the flywheel it made a loud banging sound. It never scraped against it. But I guess anything is possible. Regardless something is scraping, I second checking the timing pointer and the flexplate cover.
