Tommorrow it starts!
    I think I'm going to start working on the LTD tommorrow. It's suppose to be close to 40 degrees out. I think I'm going start on the intake and carb swap. But then I won't be able to close my hood!! I guess it'll be time to break out the saw!:hacksaw:
    what are you going to be running for a carb and intake?
      Cut it up!!!
        Weiand Stealth intake, Edelbrock carb and a 2" spacer(not in the picture ). I know it's going to stick thru the hood. That's why I'm considering dumping the hood scoop and just running a Street scoop that's painted black.
          I beg of you, PAY SUPER CLOSE ATTENTION to the intake to head gaskets, those things are hard to get right, I had to redo mine TWICE. The coolant ports leak so easily its annoying.
            Yep I know all about the gaskets. My install is a little simplier then yours since I don't have any upper intake or emission crap to deal with when reinstalling everything.
              im using an air-gap intake with a holley carb and a Moroso air cleaner. i had to basically cut out the hood support above the carb stud in order for it to fit. My end seals were done with a big bead of RTV, and absolutly no leaks.
                I use a bead of RTV in the place of the end gaskets too. I knew I'd be cutting a hole in the hood when I decided on the intake.
                  Shiny!
                    I didn't get much time to work on it so I just pulled the grill/headlight surrounds and the underhood sound deadner. I'm holding off on the intake swap until I've got enough time to get it done in one day. And I need some kind of portable lighting I can't see crap in that storage unit.
                    I'm kind of pissed. What I thought was a scratch in the chrome on the grill turned out to be a crack right down the middle divider almost top to bottom. There's not much holding the two halves together.
                    Oh I also found my cars build sheet between the sound deadner and the hood. That's the weirdest spot I'm found one yet.
                      Ive heard of it in that place.
                      You can easily find a new 79ish grille...
                        I'm hoping I can find another one. Luckily I don't need one with good chrome since I'm painting it.
                          I figured I should tell you that I haven't dropped off the face of the earth yet and I haven't forgotten about the car I told you about. Spring break's coming up next week, so I'll grab my camera and snap some pictues of it for you.
                          2007 F-150 Supercab XLT 4x4
                          1997 Jeep Cherokee
                            Sounds good. I'm trying to find some place to store it.
                              I got a little more work done. I only had about an hour to mess with the car.
                              I pulled the hood( to cut out the opening for the carb scoop ), AC compressor, lines and brackets. I also pulled the cruise crap and vaccum canister. All the vaccum hoses that aren't needed. ans a few misc other items. It's starting to look a little better under the hood. I can almost see the engine. By the time I'm done there should be about 150 pounds of parts that I don't need removed from the front of the car.
