ok i used throttle body cleaner on the intake... in the throttle body O.C. ... and now it has WAY TO HIGH idle. is there any way to adjust the idle other than moveing the distributer? and why did it make it SO HIGH??? help please... thanks
High Idle
Check for vacumm leaks too, the vacumm lines for the brake booster and the egr valve are all in that same area.Current rides - 1991 Ford Thunderbird 3.8 v6 (gas saver/DD) - New Heads/Headgaskets with ARP studs, Air Silencer Delete, 70mm MAF, Plasti-dipped Matte Black with a Silver Metalflake Overlay, Muffler Delete, some LED's, 30.233 MPG for high MPG average!
Associated Panthers:
Check voltage on the TPS sensor.
I also second the IAC suggestion. Many times when you clean the TB/Intake, the cleaner will mess up the solenoid. If the IAC is bad, the engine will stall when you unplug it.
Vacuum leak would be large if the idle is as high as your saying (how high exactly are we talking here, like 1100 or 3500?)1990 Country Squire - under restoration
I agree. IAC motor or vacuum leaks are the usual suspects.
In general, if everything isfunctioning properly, the easiest way to adjust the idle is with the addition of the idle adjustment plate from Ford (part number F2PZ-9F939-A) which goes in between the IAC motor and the throttle body.
Picture Of Spacer
i forgot to mention that it is a 89 CV btw ... sorry
i did not take that off and clean it... i sure will do that, i hope that is all that it is. if i clean it and it doesnt take the idle down does that mean it is bad?Originally posted by Ivan DYou might have an IAC valve (the weird thing at the back of the throttle body) stuck open, did you take that one off to clean it too?
yeah it sounds around 1000 ... but i dont think that it is a vacuum leak since it was running fine before i cleaned it. thanksOriginally posted by TiggieVacuum leak would be large if the idle is as high as your saying (how high exactly are we talking here, like 1100 or 3500?)
Your car idles normal in all non-neutral gears cause there is load on the engine to slow it down. The way EFI Panthers are designed is to revv up to about 1000rpms when starting, then eventually go down to 500 or so. Yours seems to be forgetting to wind down, so I'd place my bet on the IAC sticking open - to test it do like Tiggie said, just unplug it while the engine's running, if the idle doesn't change you've found your problem.
Just to make sure take it off, clean it nicely with whatever chemical you're using and make sure the valve moves freely, then unplug the harness from the motor and spray some electric contacts cleaner on both, and before you plug them back put some dielectric grease to prevent posssible corosion. After you bolt the IAC assembly back on the idle should be okay, if it still flies high then it's time for a new motor for it.
My 87 MGM has a Idle adjustment screw located on the throttle linkage. but if it was fine before any u didnt touch the screw then more then likely its a bad IAC or, all that junk u cleaned outta your T/B is holding ur throttle plate open a little...1987 MGM 126K 2" True Duel flowmaster 40's 3" tipped exhuast, Tinted 20% all way round, individual bank A/F guages, tach.
Does this happen on initial start up and clear up after the car is warmed up and you rev it a little? If so, it's probably the choke.Originally posted by 91 LTDMy 91 351w does the same thing. I'll start it, and it i'll idle real fast. If I shut it off and start it again she usually calms down. Any thoughts?
The 351W is carb'ed, so no much (if anything) from the above post is going to apply to you.1990 Country Squire - under restoration
I would also consider maybe pulling the whole throttle body off to properly clean it. If you do that, you will need a new gasket under the throttle body, and you should also replace the IAC motor gasket if you remove it. If you do pop the throttle body off, take an old toothbrush or something and clean the whole plate and body out. Its probably got some gunk that you un-stuck hanging the plate open a bit.86 Lincoln Town Car (Galactica).
