this is the first time i have had an air cleaner on it (and that is a little shorter than what im using but there is a 1" spacer on it that im not using) i think i might need that fiberglass cowl hood :chainsaw:
i think i might have to cut my hood
http://www.grandmarq.net/vb/showthread.php?t=5634Tags: None
dat's a purdy engine, and you got a purdy mouff
SuperFord Profile
Support safe sigs
-sigs should not exceed 600 pixels wide
-sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
-Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
-Total sig size should not exceed 60k
Remember, only you can prevent sig abuse....
:lol:http://secondhandracing.com/Home.aspx
updated new engine pics
finally got the valve cover drilled for the breather, got the gear drives to fit in, and installed the distributor
ther headers are summit brand dont know if they will work yet or not( ive got a sawzall, welder, sledge hammer and a machinist next door they will work eventually)if i have to make clearence i will either graft a scoop on or just build a fiberglass hood with maybe a 2" cowlhttp://secondhandracing.com/Home.aspx
