Got the nitrous plate installed today. still need to make another AN fuel line. The plate added 1/2" to the stack heighth of the carb/air cleaner. That 1/2" made the air cleaner hit the hood. So i had to cut out the small brace in the hood, and get a new air cleaner. gone is the 14" Moroso housing, in its place is a 10" chrome housing. the new one was about 3/4-1" shorter overall.
Air cleaner/Nitrous
Air cleaner/Nitrous
http://www.grandmarq.net/vb/showthread.php?t=5634Tags: None
Hell no.Originally posted by Grand_Marquis_GT
Oh yeah, is the TV cable still hooked up??http://secondhandracing.com/Home.aspx
Thats the throttle cable, it is not hooked up right there.Originally posted by Grand_Marquis_GTAh shit, looks like it is.
I didnt think you were running a kickdown cable/rod...http://secondhandracing.com/Home.aspx
it is only till i get some kinda scoop either a hilborn hat or a teardrop scoop. With the Moroso i can barely get the safety catch to latch, dont even think about actually closing the hood.Originally posted by phayzer5You're gonna suck that dinky lil filter through the carb :lol:http://secondhandracing.com/Home.aspx
My Moroso was a drop base air cleaner, i had to have a spacer under the air cleaner otherwise the air cleaner hits the needles on the bowls, and it presses the accelerator pump when fully seated. If i get a hood scoop ill try to get a flat base aircleaner like what Modified guys run.Originally posted by TommyNA drop base air cleaner might clear better.http://secondhandracing.com/Home.aspx
Nah Pete just needs to come down here , ill give him all the zip ties, and wire loom he can use.Originally posted by mrltdMan, you gotta un-clutter that engine bay...LOL
Looks great!
Looks great!
Oo... I'm glad you haven't seen mine. His looks about eight times less cluttered than mine!1990 Country Squire - under restoration
