Project Teardown Commencing
    So, I havent driven my vic in about 4 months, and well, I just got the money for the mustang multiport intake which I'll have either tommorow or Thursday. So after dinner I started teardown.
    I pulled the plug wires, distributer coil and some of the other electrical stuff topside. Then I pulled the radiator and condensor.
    A few things suprised me. First, no fasteners broke. Not bad for a 22 year old car.
    Another thing, when I pulled the radiator out, some of the leftover coolant inside came out mixed with tranny fluid. I've pulled many other radiators with integrated tranny coolers, and well, tranny fluid's never came out of a coolant hose location. So my theory is, there is an internal leak in the radiator and it's shot. That's the assumption I'm going on anyway and I'll just put a new good radiator in and an external tranny cooler. I was going to do that anyway, so at least it's not something added on
    But yea, woot! I can almost taste it!
    edit: oh yea, pics tommorow when it's light
    GMNRadio DJ, Podcast Co-Host
    95 S10 93 Accord
    None of my bolts broke either which kinda surprised me. I was expecting at least one bolt for the accessories to snap but not a single one on either the donor engine or the original engine.
      snapped bolts suck. i broke one trying to get the acces plate off to drain my torque convertor. it just made me give up completely.
        None of my bolts never snapped either, I was real suprised to hear some guys had trouble with thier exhaust manifold bolts. Mine came out with out any trouble at all on both my cars.
          Well, here's a few pics:
          Here we have what I had accomplished yesterday (4/4):
          Here we have at the first smoke break:
          And here we have at the end of the night. This one the pic quality sucks, I took it about 40 minutes ago and it was darkish out and my batteries are dying in my camera. Plus the flash sucks balls to begin with.
          95 S10 93 Accord
            Are you swapping the longblock or just the upper end and electronics?
            Nick
            88 Colony Park LS
              List of things removed tonite:
              Power steering pump
              Altenator
              Brackets for both p/s and alt
              exhaust manifolds
              intake
              cfi unit
              valve covers
              That's actually pretty much it for the night. I wanted to get the heads off, but I ran out of light. I might be able to pull those off tommorow, but I have homework and packing to do since I'm going to BFE Tennessee this weekend.
              I found it rather interesting that a 9/16, 1/2, 11/16, 5/8 and 8m sockets and the appropriate ratchet and breaker bar is about the only tools you need on this engine!
              oh, and the right hammer for the job!
              /sen
              95 S10 93 Accord
                That engine is coming out entirely, along with the tranny. I'm tearing it down in the car as much as possible because of space constraints (my driveway is sloped, not much room for an engine picker). I can lift a 302 with the pistons and crank in, so I may not need a picker, just depends on if i can do it from the car.
                I bought these from a feller at werk (pic below). I am rebuilding both from the ground up. They are out of a 84 grand marg. I'm putting the Multiport efi from an 87 mustang gt, worked over heads from a 70's era Windsor mustang (i thought they were gt40 heads, but they're not). The tranny is getting a basic rebuild kit from Norther Auto along with the O/D drum and oneway and a shift kit (and whatever is needed to hook up the tv linkage properly).
                The engine will be getting new pistons, rings, bearings blah blah blah. I havent finalized what cam I'm going to use, but it's going to be some form of truck or camper cam for low end torque.
                95 S10 93 Accord
                  oh yea, the pic in my sig is the engine in the back of my truck torn down to block
                  95 S10 93 Accord
                    Nice work man! Hope all of your plans with the new longblock work out. You have the ranger to drive so dont let time & money hold ya back.
                    -Matt
                      Nice!
                        Time for an RV cam!
                          Awsome man, good luck. Keep takin pics as you progress.
                          Nick
                          88 Colony Park LS
                            heads are off! has one hell of a ring groove in the cylinders, all even.
                            pics later
                            95 S10 93 Accord
                              pics later
                              This on the old engine? How many miles were on it? My 120k HO block had zero ring groove and visible crosshatch marks still.
