Speed Density to Mass Airflow...
    What is involved in swaping speed density to mass airflow setup?
    I'm assuming pcm and maf from a maf vehicle, correct?
    For info:
    All air/fuel intake and control systems are from a 1987 Ford Mustang GT.
    GMNRadio DJ, Podcast Co-Host
    95 S10 93 Accord
    Yep. Will also need the MAF harness and a couple spare pins from another 60 pin PCM connector. You also need to tap into the speed sensor wiring. It's actually pretty easy to do. I did a conversion on a mustang.
      The '87 Mustang GT had Speed Density from the factory.
      '90 Mercury Grand Marquis GS
      5.4L swap coming soon.
        Yup yup, 87 is SD. Probably someone did a mass air conversion on it. Iff'n you want some details on the swap, here you go: http://www.lincolnsonline.com/tech/00077.html
        Thats for a Mark VII, but same idea. ECM is in a different spot is all.
          It's not difficult... I converted my car in about 2 hrs. if you already have factory Cruise control, you wont have to mess with the speed sensor part.
          you will need a MAF ECM, Mustang unit is the easiest to find, but I hear 91-93HO t-bird/cougar units work, MAF sensor and MAF conversion harness
          you will loose the cruise control since its intregrated in the ECM on the CV/GM
          you also need some sort of air intake to bolt the MAF up to, I used a Mustang CAI that worked with the MAF I had.
          my original article with pictures
          Finally got my conversion done and the car runs better, but still needs some tuning since I used a 80MM MAF sensor from a mark 8 thats calibrated to 24lb injectors and I am running 19lb injectors. Basically you have to add 3 wires, move 2 wires and splice into and solder together 4 wire…
            His cruise controle is not integrated. I have MAF and have not lost cruise control. 92 Cougar ECU. Older panthers have a sepperate module.
              Right... I forgot older cars don't have intergrated cruise. a simple check to find out which you have.... 3 wires on the cruise servo = intergrated cruise, 6 wires on the cruise servo = non-intergrated/stand alone cruise.
                Here's the wiring differences between 5.0L EEC cars:
                http://fordfuelinjection.com/5.0Lpinouts.html
                  88 and newer were integrated. 87 and older are stand-alone.
                    Where's seneeb? We need more information.
                      Sorry, i was away for the weekend =)
                      What other information do you need?
                      95 S10 93 Accord
                        just got back in from the garage a few minutes ago. My cruise control has 6 wires going into it.
                        95 S10 93 Accord
                          The 1987 Mustang GT was Speed Density from the factory. Was the '87 GT converted to Mass Air? (We need this information).
                            No, it's stock.
                            I'm wanting to convert to Mass air
                            95 S10 93 Accord
                              Well, if the 87 is stock and you want to convert your car to mass air....you need to find a newer car. The 87 DID NOT have MASS AIR.
