I plan on swapping to the HO upper intake along with the HO TB that I have from a 90 mustang GT along with maybe fabricating a CAI. The stock airbox doesn't seem like its that restrictive, but I have noticed an improvement on other cars. My truck had much more restrictive intakes though, I had to cut part of the sheetmetal next to the radiator since the original intake only had a pin hole to suck air through.
Cold Air Intake Upgrade with HO mods
Associated Panthers:
http://www.cardomain.com/ride/2128327Tags: None
This is what I'm running right now. I didn't do any "Before" and After" dyno tests to see if I was making any more power over the stock numbers. The flat, "ribbed for her pleasure" factory air intake looked like one of the "Lost in Space" robot's arms to me.
I used parts from the MAC cold air induction kit. If this inlet tube was extended about 12" and the air filter enclosed, I think it would yield a little more power if it made any difference.
Just my
'90 Mercury Grand Marquis GS
5.4L swap coming soon.
You're drawing much warmer air in with that intake than the stock one.Originally posted by N AThis is what I'm running right now. I didn't do any "Before" and After" dyno tests to see if I was making any more power over the stock numbers. The flat, "ribbed for her pleasure" factory air intake looked like one of the "Lost in Space" robot's arms to me.
Just my
Nick
88 Colony Park LS
I have installed the HO upper/65mm TB and Bored EGR Spacer,with a custom CAI I fab'ed myself on my stock motor.With the CAI,I deleted my washer fluid/raidiator overflow tank,and cut a hole in the fenderwell which the CAI pipe runs down into and the filter attaches on the other side,making it a true cold air intake which is much less restrictive than the stocker.I also made a splash shield for the filter to protect it better during rainy days.I'm not gonna get into the dyno results because of what happened last time when I did,I'll just say It did make a difference.The HO upper,and 65mm TB and EGR Spacer will also give you a nice gain in throttle responce,the stock lo-po's are quite pitiful and should have never been put on our 302's.Good Luck!
What happened?Originally posted by Custom87"...I'm not gonna get into the dyno results because of what happened last time when I did,I'll just say It did make a difference...".
Any improvements in potential air flow with a true CAI will be magnified if you eventially do a head, cam, header, gear, etc... swap. The pitiful factory motor doesn't need all that much airflow potential unless you bolt on a N2O plate.Originally posted by 87mefullI plan on swapping to the HO upper intake along with the HO TB that I have from a 90 mustang GT along with maybe fabricating a CAI. The stock airbox doesn't seem like its that restrictive, but I have noticed an improvement on other cars.
The "new intake" will be better.
