The gasket surface area doesnt match up. I mean the 60plus mm diameter matches but the little surface area that comes off the side. One is in the corner and one is at the side. This being on the coolant side does this cause a problem with delivery and return of coolant. Wish I could send pics of what Im talking about but IM not that hightech yet.
EGR spacer mods
Did you bore out your stock EGR spacer? If you did, run a stock gasket and you should be okay. If you are trying to use a Mustang spacer, you need a Mustang gasket.
E-mail me the pictures and I can host and post them for you.
jacocksauto@yahoo.com2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
you dont have to hook up those egr coolant lines, there isnt any need for them. You can just route them off by connecting them to each-other.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Can you use the stock mustang egr spacer, or do you have to bore out your stock one? I'm putting an 90' HO intake and TB on my lopo soon.Current rides - 1991 Ford Thunderbird 3.8 v6 (gas saver/DD) - New Heads/Headgaskets with ARP studs, Air Silencer Delete, 70mm MAF, Plasti-dipped Matte Black with a Silver Metalflake Overlay, Muffler Delete, some LED's, 30.233 MPG for high MPG average!
Associated Panthers:
sounds like you may not have bored the spacer straight. the back side does get thin and may have sealing issues.
As long as the center is making proper contact so you don't have an air leak, I'd just cap off the coolant lines and not worry much about it.
87mefull: Don't think you can get away with a Mustang EGR spacer. The throttle bracket attaches to the spacer, and the brackets are not the same on a Mustang. You could do it if you make up a custom throttle and tv cable bracket though.86 Lincoln Town Car (Galactica).
The mustang one requires a bit of work to fit. Boring the stocker is the way to go (well, actually a 93-95 lightning one is the SHIT, but is impossible to get)...
I have a spare stocker sitting around I can get bored if you need it.Builder/Owner of Badass Panther Wagons
Stock can only be bored out to 63mm, so if you want to go with a 65mm throttlebody, you'll want a Mustang spacer. It's easy to modify the stock stuff to work. I had a little angle iron laying around and cut to fit (Scott's idea).2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
got it bored yesterday, another 50 freakin dollars.Hope she is right after i get it together, again. By the way, for those who responded to my fuel injector post. What kind of place professionally cleans and test these sombitches? I talked to NAPA and he didnt do it
Wow, $50 is a ripoff for an EGR spacer boring. $10-20 is reasonable. Its an easy job that any shop with a milling machine or a lathe can do in a few minutes.86 Lincoln Town Car (Galactica).
