Where can I rum my water temp line from. It's mechanical. I ran the oil line no problem, drilled the hole. The only problem with the water line is that it has the spring around it. The only idea I have is to wait for my dad to bring me home the right drill for the bigger drill bit we have to make the whole. Is there anywhere elese I can run it threw?
Water temp gauge
Water temp gauge
1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
4 Door Muscle
SupermotorsTags: None
That's where my tach is. I took out my cruise conotrl and there was a spot there. I missed by an inch. I'll have to wait for my dad to bring home the bigger drill.1989 LTD Crown Victoria LX.
4 Door Muscle
Supermotors
I think thats where mine is run too. Somewhere near there anyway. Check on the engine side and see if there is a rubber grommet close to that spot you can knock out.86 Lincoln Town Car (Galactica).
I got the drill bit I needed and drilled one threw the firewall behind the head1989 LTD Crown Victoria LX.
4 Door Muscle
Supermotors
