How the hell do you guys get to that clampdown bolt for the distributor? I set my timing at 12*BTDC several moths ago, but I no longer have acces to the tools I used then (whatever they were), and I wanna try the 14*BTDC thing. I have a set of sockets, deep and shallow, but the extensions keep bumping in the distributor and the sockets can't really grab the bolt's head well - will a small flexi-joint do the trick?
Adjusting the timing...
need an offset wrench or the special distributor wrench. I used a torch to bend an old wrench I had till I bought the right one.2000 Grand Marquis LS
Mercury Owners Group member
Use a short well 1/4" drive socket, a u-joint and an extension.http://secondhandracing.com/Home.aspx
I use a flex joint and socket. Works fine.86 Lincoln Town Car (Galactica).
How's it running with 12*BTDC? Does it run better with advanced timing with the HO upper intake and TB? I might be swapping to the same intake and tb soon.Current rides - 1991 Ford Thunderbird 3.8 v6 (gas saver/DD) - New Heads/Headgaskets with ARP studs, Air Silencer Delete, 70mm MAF, Plasti-dipped Matte Black with a Silver Metalflake Overlay, Muffler Delete, some LED's, 30.233 MPG for high MPG average!
Associated Panthers:
The new intake made a difference to low-end power, she seems to be picking up speed easier now. I'll do the 14* timing on Friday after classes (I have to crawl under the car to mark the balancer so I can see it from above the engine). Oh, and exhaust noise changed too, its more low and growly now, compared to the standard crack glasspacks make.
